Remember that the 6 ohms is nominal. . .it is higher and lower
at different frequencies. . .You really need to be concerned with
the impedance plot and frequency response. . .Many woofers are
rated at 8 ohms but they can drop to 4 ohms in the 300 Hz range
quite easily. . .then peak in the high 80 ohms in the +10 kHz range
and have a free air peak in the 60 Hz range. . .Why. . .don't let it
bother you. . . there are more important specs. . .or is it a conspiracy.
Correct:
Resistance is DC or AC and doesn't change with frequency.
Impedance is Frequency Dependent! A voice coil is basically
an inductor = rise in impedance because of rise in frequency.
Thinks alter this like mass of driver, and restricted movement
because of air or mechanical.
Thanks all This is what I thought and I picked the drivers based on frequency response. Just needed that final bit of re-assurance prior to the start of the project.
The drivers I chose were
VIFA P13WH-00-08
VIFA D26TG-05-06
I'll be making two pairs - one for me and one for my mum. Of course I'll post progress pics!
Cheers!
VIFA P13WH-00-08
VIFA D26TG-05-06
Cheers!
Don't worry about different nominal impedance in the tweeter and mid woofer as it's not an issue. You don't need an 8 ohm tweeter to go with a 8 ohm woofer.
Manufacturers are heading for more lower impedance drivers not to give your amp a heart attack but to increase SPL. Note how many of the newer tweeters are 4 ohm nominal. The lower the impedance the higher the SPL with all other things being equal plus there is a side benefit of lower inductance.
A good example is the 7" Revelator mid woofers with 3 versions available and SPL at 2.83V.
8ohm version - 87dB
http://www.tymphany.com/18w-8531g00
4 ohm version - 90dB
http://www.tymphany.com/18w-4831g00
16 ohm version - 83dB
http://www.tymphany.com/18w-16531g1
8ohm version - 87dB
- 6ohm tweeters
