6n16b buffer on a nakamichi cdp
And also no reason for Rload ;)
Come to think about it, no reason for the hole circ(us)uit :p
Mona
The reason for "rload" is to discharge the cap, i.e. a bleeder actually. I would use all 3 resistors: on input, output, and grid leak of the same value, like 220k, to save money.
The reason for the circuit is, the majority of modern designers think of "voltage amplification" forgetting about power transfer. As the result, input/output impedances are non-linear, so a tube buffer "mismatch" them pretty well isolating power-wise from each other.
As i understand it the thing has to be mounted inside the cabinet, the caps will discharge on the ins and outs.
If you lik to "isolate power-wise", put a j-fet in between :D
Mona
