6L6GC/EL34 SE Stereo Design
Hey, I am building a single ended stereo amplifier and want to allow it to use 6L6GC's and EL34's both in triode mode and ultralinear mode operation. I plan to incorporate a switch for choosing triode versus ultralinear mode. My output transformers are Hammond 1627SE's (2.5K Primary), and my B+ is roughly about 385V. Both output tubes I have are new from Electro Harmonics (6L6EH and EL34EH). I plan on using an old E88CC as the driver tube.
I know the choice of E88CC as a driver tube is very arguable -- and comments from either side are welcome -- but since I already have these tubes, I'd like to use them.
Anyways, getting to my questions:
-- What do you recommend for biasing the tubes - should I go for a switch to change for the two tube types? - Or just use one operating point? Is the schematic at the Fi Primer (http://tinpan.fortunecity.com/saints/668/primer/index.html) a good idea for using both tubes? Or how about something in the range of 375V and 65ma?
-- And in designing the driver stage, how do I know how much to amplify the signal before sending it to the power tubes? Is it just limited by cathode bias minus a few volts, or are there good rules I just haven't found yet?
Thanks in advance, I will be away from any computers for a few days, but will be back soon. I hope this is not too simple of a question, but I am without a tube manual and so far I have only found one source of plate characteristic charts for ultralinear mode operation -- and it doesn't seem to agree with the Fi Primer's 6L6 amp's cathode bias and current info.
Thanks,
-=bart=-
Go for it.
The two tubes are pin-compatible as long as the suppressor is taken care of on the EL34, but the difference in Gm will need a rebias. Changing mode from triode to UL to pentode doesn't require a rebias if screen voltage is the same (in the circuti shown, it is).
For the driver stage, generally your peak drive (to the output tube) is equal to the grid bias voltage, which since the grid is held at zero by the grid leak, is the cathode's self-bias voltage above ground. From that you can calculate if your driver has enough gain (given a certain signal input), especially including how much NFB you want to add.
Tim
A couple of tips
I think you stated you already had an OPT. Just wanted to mention that using a 2.5k OPT will create alot of distortion. Higher would be better in this regard. So if it sounds "funny", part of the problem could be the low Z tranny.
Secondly, the new JJ6922s are pretty darn good tubes, sonic wise. If you get the chance, you might pick one up and see what you think.
Just a couple of thoughts.
So, If my supply is in the range of 350-375VDC, then will a 390 Ohm resister (like in the Fi Primer's design) do the trick to ~conveniently~ bias an 6L6GC and El34 in ultralinear mode? And Triode mode?
The reason I ask is that the only ultralinear graphs I have call for a lot more cathode bias than in the Fi Primer's design.
-=Bart=-
Amplifier Success
Hey all,
I just gave my amp a first try -- and it worked right from the start! I still have a little work to do to finish it up -- ie: solder in a few more discharging resitors across the power supply caps and then finally turning the thing over from off of its back and making a bottom cover. Anyways, I'll post a pic and schematic when I can, and eventually I'll put more on my website (that's another story). Anyways, I'm really happy cuz I took a good while to design and build this thing, and it actually works. It's about as loud (or not loud) as I thought it'd be, and amazingly there is virtually no hum coming out of the speaker -- but the hammond power transformer does vibrate and hum a bit. That's ok. Anyways, this is all awesome and now I've got a stereo using a 6922 or 6DJ8 and either EL34's or 6L6GC's (maybe others too????) in either triode mode or ultralinear.
Yeah, now I've got an audio and a guitar amp. Cool. :)
By the way, any suggestions for tweaking and learning more are welcome! I put 100 ohm resistors underneath my input tube's cathode bias resistors so that I could possible experiment with global neggative feedback. Any ideas????
Very Cool!!!!
-= Bart Mc. =-
Here's some pics, for those interested:
Without tubes...
Ok, so I don't know what is going on, but I'm a newbie and still under moderation. I've tried to post two pictures under the size limit twice, I did attach them and I even checked once with the preview (and remembered to check if attached after that). So, any reasons why I would not be able to post pictures?
-=bart=-
Questions
So, what do you suggest I do to the exposed aluminum of the chassis to keep it clean? I'd rather not have to take it all apart and sand and spray ... and so on. Any ideas????
Just FYI, the little switches next to the octal sockets are to switch between ultralinear and triode strapped mode. The bolt next to the miniature socket is the chassis grounding point.
The ventilation holes also double for mounting holes, and other than that the chassis is very plain and boring. Any ideas on how to construct a bottom cover that raises and allows airflow into the amp??
Eventually I'll get to a schematic.
-=bart=-
You could try diy anodizing. You only need a car battery charger and sulfuric acid. Anodizing will create a very tough protective coating on your aluminium. You can even use dye to color your parts, otherwise, your parts will keep their natural color.
Take a look at these :
http://www.focuser.com/atm/anodize/anodize99.html
http://floridamu.org/matt/general.html
I hope this helps !
