Here goes...let me start by qualifying the simplicity of my question : I am a novice, hobby-type tinker with most of my interest in musical instrument amplification.
Ok...that said : I want to convert a 6L6 powered amp to EL34 due to space constraints. The filament tap is rated at 3 amps, so that is not a problem.. what changes must I make . It is cathode biased, class AB1. Any help is appreciated...God bless !!!
One consideration is that the 6L6 is internally connected between it's cathode and suppressor grids. The EL34 is generally not. So you may need to rewire some of the socket to ensure an appropriate connection for the EL34's suppressor grid.
Check the pin diagrams for each and compare to what you already have there. Keep in mind that there may currently be a resistor mounted on the currently "unused" suppressor pin for convenience. You may need to re-locate it.
EL34s can also call for a higher value screen resistor in comparison.
I’m not familiar with KT-77. I’m only familiar with the 6L6 vs EL34 thing since I made that change on a guitar amp I once owned. There was no audible change in tone but that amp had much going on inside that prevented the true tube sound from coming thru. I sold it and bought a ’71 Fender instead.
