6KN6-PP-guitar slave
Halo! Have anybody experience with 6KN& or 42KN6 tubes? I just finished PP guitar "slave" amplifier, with fantastic sound and plenty of power (~28V/8 ohms at start of clipping=~100W RMS; ~23V/8 oms=70W RMS with ~2%THD).
OT, "home made" have 1760 t/primary for 2Kohms(4x440t/0,40mmCuEW), and 78t/secondary(1,50mmCuEW)for 4ohms plus 34t for 8ohm(1,25mmCuEW), all in same direction.
P1_P2_S1+S2_P3_P4
Start P1 to anode1; end P1 to start P3; end P3 to +340V
Start P2 to +340V; end P2 to start P4; end of P4 to anode2
Start S1 to ground; end S1 to start S2 and to 4ohms output; end S2 to 8ohms output
Iron: EI-type(40mm) and 50mm tall (S=20cmcm/br; S~18cmcm/nt)
Test results:
Uin:1V (sinus, RMS); Rout: 8ohm (resistant 400W/noninductiv);
THD:2%
F Uout Pout
40Hz 14V 26W
100Hz 23V 70W
1kHz 23V 70W
5kHz 21V 58W
10kHz 18V 43W
THD:10%
40Hz 25V 82W
100Hz 28V 103W
1kHz 28V 103W
5kHz 28V 103W
10kHz 21V 58W
Output tubes operating point at Pmax (Po):
Ua=340V(346V);Ug2=150V(152V);Ug1=-38,5V(-38,3V); Uf=6,33V(6,28V)
Ia=2x60mA(2x205mA);Ig2=2x0,5mA(2x16mA);Raa=2kOhm;Rg2=2x100ohm
