6j4+6p6 hifi preamplifier kit!
I keep losing that Link...
attachment.php
No Poop? ...Learn something new Every Day..Thanks...
And, if you want to lower the Gain, it's Way Easier to just parallel the 24K...Use an OnLine Calculator...I've found that a 10K over the 24K gave 7K, it helps a Bit...Not very much, so I then tripled with a 5.5K that made it around 3K, but I think that Messed up the Sound...I'm keeping it at 7K for now until the New Alps gets here on the Slow Boat...
Now, here you go Ray...Remote Motorized Alps, with 4 Inputs and Mute...Only 2 Inputs now, and the LEDs are kept underneath...The IR is Relocated from the Board through one of the Holes around a 6AU6, and it's powered from the 6X5's 6.3V...It really Sounds and Works Great! It's the Best Upgrade Ever for a Tube PreAmp Kit...
attachment.php
