These tubes were used for regulation, however, I cannot find any examples of how to use them in a PSU. Any help with how you would set these up to regulate a supply for a SE amp would be appreciated. Would you use them like a 6AS7 and the likes? I decided I really don't need to build another amp but I have 2 of these tubes hanging around I figured I'd use them for something....
well , you must start somewhere ;
good place : http://www.pmillett.com
read .
then ask here what you need
read .
Re: Give me some credit II
shoot me with email , and I'll send you one thorough tutorial for series voltage reg .
it's for another tube , certainly ..........
>choky@neobee.net<
athos56 said:I've spent days looking at that site, its great.
Anybody use 6C41C's as they were intended?
>choky@neobee.net<
athos56,
I have an ampl . 6C41C & EF861. Output tube has Ri=apr. 200-300 ohms,
depend of Ia, and very great sound!
My old version is with preampl.6П15П /russian/, on the foto. Ra output transf = 1,5 kohms, Ia=130 ma.
http://picasaweb.google.bg/azazello52/Amplifiers#5195304551304966610
If You interest, I will send a schematic.
azazello said:athos56,
My old version is with preampl.615 /russian/, on the foto. Ra output transf = 1,5 kohms, Ia=130 ma.
Wow! How long do you build your stereo amps?
That 6E1P with no getter flash looks very cool!
http://picasaweb.google.bg/azazello52/Amplifiers#5253639715948192882
nah, just the raw B+ minus the reg voltage must be under 300v.. that's the part it actually passes..
so 550V raw B+ and 300V reg'd output would be ok.
but..
checking data sheet - says Va = 450v max, 600v on a cold tube / turn on, not 300v.
Vhk is 300v though, so you may need a seperate fil winding, if output is >300v
but..
- Tubes / Valves
- 6C41C in a PSU regulator?
