6C33C-B Valve Preamplifier
Hello,
Here is one another preamplifier circuit diagram,
it use 6C33C-B Tubes.
It is little unusual, using very powerfull tubes.
I tought it might help someone.
Best regards,
Kristijan Kljucaric
http://web.vip.hr/pcb-design.vip
diyAudio Senior Member
Joined 2002
FREE ELECTRICTY PLANT?
Hi Christian,
Thanks for the circuit,I'd seen it before and I nearly fell off my chair laughing.
Can anyone justify this for a preamp?
I know I can't...they could have made a heafphone amp from it at the same time I reckon?
Flamin' overkill,I tell you...
ROTFLMAO.:bigeyes:
Cheers,:)
Joined 2002
Watch me...
John...let's look at the facts here,
Virtually no amplification and a hell of a lot of heater power going down the drain.
If it's low Zo they were after it can be better easily at the expense of all amplification...who needs it anyway?
What's going to be next?
300Bs as rectifier perhaps?? Oh,yes Sir much better sound,Sir...:xeye:
Cheers,;)
you could re-arange it a bit and add some gain & a splitter, and have a power amp.. otl.
got some 6SN7s, 6DJ8s, 12AU7s, and 12AX7s today, with some little input transformers.. what to build? ;)
My friend made a headphone amp using 6DJ8s, and parafeeding the output to an input trafo (used as an OPT in this case ;) ), might try that.
hmm.. seems i went a little off topic :boggled:
too damn lazy to go outside and work on a chassis though.. too cold :(
