6AU6 Triode Mode
That pin configuration for the input stages gave the best screening between heater pins and grid pin and anode pin.
http://www.retrovox.com.au/6AU6pAWV.pdf
I also liked the way the schematic showed local star grounding for those input stages - published article in Radiatronics 143. The amp used the prototype Williamson OT made by local Ferguson's manufacturer.
Yuppers: I've seen that before, and have a complete set of triode plate characteristics for 6AU6 pents. The really good thing about this is that the u-factor of the 6AU6 pseudotriode falls nicely between that of the 6SN7 and the 12AX7, useful when the former can't provide enough gain and the latter develops too much. It's also much more linear than the 12AV7, with a similar u-factor.
Using the screen as the "plate" of a triode while the plate serves as an electrostatic shield is also a neat trick for electronically noisy environments. Since the screen isn't surrounded by a hot anode, you could probably bust the 2D rating without ill consequences.
Very convenient when you need a singleton triode, and want to use a mini VT, as there aren't many of these out there. There are more Octal singleton, small signal triodes, as most of the mini's are nine pin dual triodes.
Reactions: 1 user
From Figure 3 of the Radiotronics article, a low power triode model for the 6AU6:
