pengboon said:I didn't have a 1k, so I used a 390R, didn't help one bit.
390R should be fine on these tubes. Did you try rotating the plate chokes 90 degrees? Also, is Rk bypassed? If not, try adding a cap as a bypass, or replace the resistor with an LED.
- Tubes / Valves
- 6688/E180F line stage?
