Subwoofers aren't something I know a lot about, except they often use big and sturdy and expensive drivers:
GF 200 - 2 x 4 Ohm | Visaton
TIW 200 XS - 8 Ohm | Visaton
Neither of those Visaton Units are cheap.
More affordable is this:
W 200 S - 8 Ohm | Visaton
In 15L it won't go hugely deep in my opinion. With a bigger reflex box it can be thunderous. The WLM La Scala used it, or its 4 ohm sibling.
Happily you can model Visaton easily enough and play around with the possibilities.
Software | Visaton
https://boxsim-db.de/kategorie/systeme/subwoofer/
Software | Visaton
I can sell you a pair of 18W/4531G00 if you want, EUR120/each would be fine for me. They`re in my speakers now but I am going to a 3-way for home use and want to use the new 18M midrange, hence these are unneeded. They can work well in 14l sealed but won`t give you 40Hz. None 6-8" will even at -6db, if you want this - go bigger in diameter. Sonido have nice units.
I was fiddling around with my take on the WLM La Scala Monitor. Handily my boxes are 22L like the WLM.
The Visaton W200S-8 is definitely a reflex midbass. (FWIW, the tweeter is a cheap and cheerful Visaton TW 70). It really rumbles. Stuff the ports and it loses bass a LOT. You'd hardly need any filter with it in a reflex subwoofer in my opinion. Hope it helps.
Thank you. I forgot to mention, that it should cost less than 120 €
SW215WA02
SW215WA01_02
Strassacker: Loudspeaker, Coaxial speakers, Driver, Tweeter, Mids, Woofer, Subwoofer, Components
You might have a look at 8" car subs to get 40Hz with any volume(loudness) in that volume (space); i.e. the older JBL gto804's with 11,5mm xmax are great. Atm I'm listening to 2 of them in ~12 liter sealed boxes, and they play the Prodigy lows (40+) very nicely without eq. (indoor, placed in front of a wall) I have not looked at their current models.
Yes, looks plausible: Dayton Audio RS225-8 8" Reference Woofer
OPTIMUM CABINET SIZE *
Sealed Volume 0.44 ft.³
Sealed F3 66 Hz
Vented Volume 1.17 ft.³
Vented F3 38 Hz
I see FRD and ZMA files at Parts Express. Those import into most simulators if you really want to be the pro.
Sealed F3 66 Hz
Vented F3 38 Hz
- 6" - 8" woofer
