Hello everyone,
I would like to build a small tube amp with 6021 as dirver / phase splitter and 5902 push pull in the output for driving an electret stax headphones.
The motivation is to fit it into the existing adapter box and use the trasformers for this project.
What do you think of the project in general and any part in particular.
Any info will be welcome.
Thanks.
Glass_painter
Thanks.
Glass_painter
Hard to tell without knowing the electrical characteristics of the Stax adapter you have in mind.
Hi Frank
I am refering to the SRD type adapter which has two step up transformers inside only.
The idea is to use these transformers as output transformers connected to push pull 5902, connect two capacitors to the transformer primary and to the headphones stators.
In addition, when the eletret headphones are not connected, it can still drive regular headphones as well.
What do you think?
Thanks.
Glass_painter
What do you think?
Thanks.
Glass_painter
Glass_painter,
I also own a Stax electret headphone, the step-up transformers in the adapterbox are not that great that they deserve a seperate tube amp driving them.
I have made a tubeamp driving the Stax direct without transformer. The improvement in soundquality is quite alot.
So I would suggest if you want to make a seperate tubeamp for your Stax, do it the same way.
You can find projects at: headwize
Dick
Dick
Hi 865,
Yes, it can be real nice to exchange views and opinions. You are more then welcome to contact me at glavi6@walla.co.il.
Hi Dick,
Can you tell me which one of them did you use in the headwise project section?
Second, I would like to use the transformers only as loads to the tubes, the sound is going directly from the tubes to the stators via a cupling cupacitor, this way the quality of the transformer is less of importance???
What do you think?
Glass_painter
Hi Dick,
What do you think?
Glass_painter
djmiddelkoop said:Glass_painter,
Dick
Absolutely! If you're going to go to all the effort to build a tube headphone driver, ditch the crap STAX transformers. Not sure they'll be suitabe for anode loads either, but I doubt they will. I've been direct drive since I bought my first set of Lambda Pro's in the mid 80's and wouldn't go back.
There's also a decent little design on Tubecad, somewhere around 2001 in the archives there.
headwize project
The first schematic (figure 1).
Dick.
http://www.tubecad.com/november99/page2.htmlGlass_painter said:Can you direct me to additional schematics of direct drive amps for electret headphones?
http://www.tubecad.com/december99/page2.html
- Tubes / Valves
- 5902 subminiature audio pentode
