50W Stereo Kit amp runs for 1 min, clips then turns off.
do you have a center tab like this?
Fuses checked. The results are not good. The positive rises on startup to around 32.5V and the negative starts at about -7V and rises to about -3.5V. This is the problem. No idea what next.
you are missing the V- voltage!!! Does your transformer have a CT? Did you check the Bridge rectifier if it was connected the right way? the ~ is for the AC from transformer and the - and + are for the V- and V+ voltages
Here're some new photos. I also took out the componants for the 15V rail. Bridge rectifier is the right way around. The V- voltage is indeed missing, no idea why.
