4780 stereo, parallel, bridged, single sided
Here is an all in one pcb for LM4780.
There are four compulsory jumpers.
The pcb is stereo ready, that means no cuts/bridges are necessary for stereo.
This is an improved version of the design posted here
Also refer the above link for help in assebling.
Gajanan Phadte
component layout
Will you be so kind to mark all elements (layout) on the PCB.
Refer post #14 in above link for values.
4 Orange jumpers are mandatory for all configs.
Green for parallel, follow fig on datasheet
Pink for Bridged, follow fig on datasheet
There are blank spaces for extra filter capacitors, if needed.
Blue are resistors, purple are caps
Gajanan Phadte
For the benefit of desperates...
I made a PCB for my friend using laser printing method.
BUT I did not follow the method in-toto.
The method says soak the paper and keep removing the paper material leaving the plastic on the PCB. Instead I just pulled the paper off slowly and the print remained on the copper. Worked like press and peel.
It was a trial and was quite good for the 1st attempt, and I used ferric chloride solution for etching.
Some practice is needed for better results.
The paper used was Desmat Premium.
By the way, the polarity markings +/- are reversed on the PCB. Take care.
Enjoy
Gajanan phadte
