I'm planning an Aleph J which needs +/-24V, and I'm thinking of using Jensen 4-pole caps in the power supply - but I'm not sure how to wire them. Jensen's application note only covers single-ended supplies. Would this work?
Yes you can do it like that.Keep in mind that input and output can be the other way around without problem.( not + and - !)
If you do your wiring the right way, those expensive elco's are not needed.
Mona
Ooooohh!! Yeah, those are expensive, but some say they're worth it, and there's only one way to find out for sure............though I'm not completely committed to them yet.
