4 channel conversion to mono 1 channel
If this amp doesn't have bass boost, an EQ circuit may help.
If it does have bass boost, changing the frequency may help it sound better.
You don't need a bridging circuit. The amp is already bridgeable.
Using a different amplifier circuit with this power supply will not make it sound better (assuming that the amp is currently in good working order).
