3way XO help greatly appreciated!
Ex-Moderator R.I.P.
Joined 2005
As an example lets look at midrange highpass
You use 29uF in series and 4.0mH in paralel
In my own speaker I have 68uF and 4.0mH/10ohm, giving a bit lower crosspoint, but not that much different
You will probably find by listening that you could do with the series C only - I have tried it and it sound OK, some would even prefer it
Fact is that the paralel INDUCTOR doesnt do much difference soundvise - actually the benefit from the paralel inducter/resistor mainly is in the upper register
What it does, affects the phase a great deal, and have subtle but important influence on sound - crude ?... I think not, quite the opposite ;)
Alright, heres a couple of graphs for your analysis. These are done in Bagbys' crossover designer 5.1. It may take 2 postings, I don't know their sizes...............Question: What is Filter Transfer Function?...........What does it indicate. How does it differ from Response graph in form and function? .............Respectfully.......Omni
OK, it's takin 2 posts to get both graphs on here............same questions apply from post above...................By the way Grant.........I need you to figure out what size capacitors to hook up to Frankensteins bolts.....................LOL...............Omni
Omni,
Sorry I can't help you with Mr Bagby's designer, I still haven't used it. But here's my latest xo, with offsets 0, -.75 and 1.5 inches. These are the coils DCR's: (ohms) 9mH 1.2, 2.5mH 0.8, 0.6mH 0.4, 0.35 mH 0.4. The highish 1.2 for the 9mH was a deliberate attempt to get its SPL to better match the CA. The CA 'dip' is now not too bad I think? I'm still trying to refine this xo for you. If we both sim it in SW, we might together come up with something fairly decent.
Re: using Zaph's CA tests, I don't really know....guess it wouldn't hurt to try? Btw, the latest xo values seem a bit peculiar?, but the SW graphs generated from it seem reasonable and the initial broad and deep dip resulting from the new offsets (above) has mostly been
eliminated. best regards, grant
Tinitus, thanks for your input. When I get some spare time I'll try it and let you know the difference (in SW).
Omni,
I just noticed the CA response in your 1st and 3rd graphs.
This looks to be unfiltered frd data for this driver? Am I right? The filtered response in my last plot looks very different to your CA graph. Does this make any sense? I have to be careful, so as not to confuse things, as I seem to be error prone lately, lol. grant
Grant, thanks for the link............I printed the tutorial and again have more to read, and thats cool..........I realize you can't help with Bagbys 5.1, but I think that us simulating in different programs, and comparing notes may be a good way to figure out the glitches,..........Also, I am gonna take your crossover components simulated and run them in 5.1. This will give us a chance to get another perspective.................Tinitus, I was working late last nite, didn't get a chance to post schematic......I will get that up here shortly, and yes, midrange polarity is reversed on those sims..............Respectfully...........Omni
Omni,
I think (cautiously) we're there! Have a look at the attached xo (latest offsets) and response chart.
Maybe its time to crack open a beer to celebrate? This latest xo is as simple as I can get it - it doesn't look too shabby at all! In fact, its slightly smoother than my previous xo with 2 extra coils and a cap! , except for a 1dB greater dip around 6kHz, but that shouldn't be noticible. I decided to pursue my initial idea of least complexity after being encouraged by Tinitus's worthwhile design philosophy of 'keeping it simple' and comment regarding parallel components. Indeed, Tinitus approach in this respect seems to be valid for your drivers individual response.
Anyway, I think this design is worth implementing, i.e., if you are happy with a 9mH DCR=1.2 on the Peerless (this was the lowest inductance I could get, to match the CA). Eagerly awaiting your comments! grant
(I said cautious above, because I haven't considered the impedance etc, just yet) Oops nearly forgot, the tweeter is about 20dB down at Fs, so I think it will be ok.
If anyone is reading this and would like to comment on the validity of my last Speaker Workshop simulation, then please do so! I'm after constructive criticism, as I'm still a beginner. To me, *superficially*, it looks great and feasible, but could there be other issues that need to be addressed?
Also, please, if anyone has data/experience with these old Vifa drivers,
P25WO, D75MX and D25TG (for my system), I'd be greatly appreciative! And if I can help you in any way (doubt it, lol) I would.
many thanks, grant
(my D75's are working again, a soldering problem)
Ex-Moderator R.I.P.
Joined 2005
Well, very nice BUT I might have misplaced my words
MIDRANGE:
As to the paralel inductor of mids highpass - I did say that you might not HEAR much difference if its there or not - But I also said it is still needed
I think you should try 33uF in series and reinsert paralel inductor with a resistor
AND try a smaller series inductor on lowpass
TWEETER:
Same thing - you still need the paralel inductor with a resistor
Attenuation - try 1.5 ohm
But interesting work;)
