360 degree phase switch
A 360 degreees phase-switch would look like that ;) :
Charles
note that for good quality it must be at least a DACT switch, with three layers of gold
Now serious: a 360 degrees phase switch means you have exactly the same signal as before. You problaby mean a 180 degrees phase switch...you can accomplisch this through an extra inverting amplifying stage, or just connect your speaker wires the other way around... (well, that's what I learned)
