3015LF Enclosure Plans - SS15 with cone correction
where you put the driver on the x5b ?
Maybe it's better to create a different thread to discus the x5b.
The driver is placed where the color changes, the driver placement are defined by the models available on Hornresp, in this case it was the CH3. Check attachment #1 and remember always to check System Model.
DL for doing sims
The sim output are available at the spreadsheet page inside the CAD files that you download, the user can also export the TXT file to hornresp with all automated options available.
Check the 1st image from Tips and tricks session or attachment #2
https://freeloudspeakerplan.rf.gd
is kind of strange that the NZONE SS15 is 224L vs the original SS15 that is 230L but the NZONE still hit lower
maybe the diferent panel layout inside
Width play an important role for volume, mine are wider for instance.
The FreeCAD model for the THSS-1 is the model I built.
What counts for low frequency is the horn length not box volume. Volume will contribute more to SPL.
