300W SMPS for amp. from PC PSU
@mayster
Reverse current or voltage feedback
@psychosatic
Yes,of course
@panos1
No,it must be toroid with high permeabilty like in CFL lamp or similar...
You can try ee16 from psu,it's used as BDT in PC PSU.Only you should add small gap in core,no need for rewounding.
Because it should be high permeability one.You can use original E16/E19 but you must add small gap.If you don't add it,transformer go to saturation and whole inverter works on ~10kHz which is small.
Yes I have pcb,but I don't know where is it.
I'll search now...
I find PCB:
  • Uni4s.ver2.pdf
  • Uni4s.ver2 raspored.pdf
