2N5566 on CODA CLX preamplifier
Does single J-fet which I use instead of 2N5566/NPD5566 in CODA CLX preamplifier ?
On my hand are 2SK389, LS844 but I want to test at single J-fet which I can substitue after original was broken.
In my searching are 2SK170BL, 2SK370, PN4393, 2N4393, BF245B and 2N3819
Anadigit
This's my CODA PCB.
A few days it will be able to a DIY PROJECT ! (sorry for my bad grammar)
May be it's a B1's killer !
:cool:
he he he
Anadigit
Semi completed PCB
This's my CODA CLX PCB cloned.
There's no power supply, in my idea I have Threshold Fet 10/HE on hand and I decide to use its adjustable supply rails.
I don't like PGA2310 or CS3310 because of it made me not a purist high-end solid state !
Anadigit
The one and only
Joined 2001
Probably the boys at Coda use the 2N5566 because that's what we
used at Threshold when they worked there.
It's a perfectly fine part, but I doubt that it's very available. The
2SK389 would be preferred these days.
I do have a drawer with some 2N5566's and also some IT505's, which
are matched pairs with cascodes that we also used at Threshold.
:cool:
Questions for ANADIGIT
Coda_CL_Preamp
Following schematic what kind of transistors are
Q1 and Q2
Resistors R4 and R7 are 100k (1002) or 1M (1003)
Capacitor C2 (47uF) is Elko or bipolar (orientation)
Led3 (D2) is green ,red or...
Power supply voltage is +/- 15v or ...
can you measure voltage across R1 (150 Ohm)
some input and outputs are balanced , how they made it ?
Thank you very much
ANADIGIT
Can you tell me for Q1 what mosfet (Type ,mark)
Q2 is MPSW92(pnp or MPSW42 npn)
What it in the left side of preamp (picture left.jpg)
something like dual fet or...
Can you post a few more pictures of preamp - please clean the dust first
thanks a lot
:cool:
Hi Mr Nelson,
I know it is a pretty old statement... but do you still have some of these 2N5566 ? I'm in France, so I need to fix one channel of my Coda 05r myself...
Hope you will answer, whatever your answer may be !
Thanks in advance
my email : nbocquet@hotmail.com
