And R1, 100 k grid leak resistor is there, measures 100 k and goes between grid pin and ground?
I have 100K pot, isn't enough?
Your circuit works fine now. Don't change anything except for the B+, which needs to be lower so that you measure 140-150V on the plate.
Thanks Iko.
- Tubes / Valves
- #26 pre amp
