2-way Unity Horn from 300Hz (some noob questions)
Little update: you can loft more than two shapes to ceate tangency
In my opinion
A horn was/ is built around a driver
Nowadays with dsp the drivers are manipulated to fit the horn
Danleys got it nailed in this day and age
Altec/jbl westrex klang et al, had it in days gone past
Speakers What’s new is old (horns) insteps DSP game changer
We need to return to high sensitivity drivers and exploit:)
Back to fusion again... this program is like all programs i ever used combined...
Seems like a good start, but the corners are not 100% correct.
Don't know whether this helps, but when I lofted, I lofted with the guide curves going into the centers of the rectangular part's sides (not the corners). Better? I don't know, it's just what I did and left it that way.
Edit: oop, looks like you did that same as I did, too (I think? Not sure -- or did you loft with 8 guides?). What part looks wrong to you in your result?
