hi, im building a headphone amp based off the cmoy amp on tangentsoft. im using opa2132p op amps. my question is... i would like to make it a two channel amp (2 stereo channels), and was wondering if i needed to do something special when it comes to splitting the input signal to go to both opa2132's? can i do this or no? also i made my own psu (from scratch) which seems to be working correctly(im stoked on that) putting out 20vdc. can i also split that power source to go to both opa2132's?
i'd appreciate some help.
Are you talking basically talking about 2 amps running off the same input signal and power supply?
If so then you could just duplicate the circuit - but you may want to add another opamp running at unity-gain in-front of the existing op amp to buffer the signal.
There should be a bunch of diagrams on www.headwize.com under Projects - look for something along the lines of 'distribution amplifier'.
As long as the power supply can provide enough current you can split it off to feed as many components as you like. The OPA2132 will feed 40ma into a short circuit, so as long as you can feed 2x that you'll probably never had an issue. You might want to add additional capacitors between v+/v- and gnd.
I think I see your confusion, so I'll try and help.
The OPA2132/4 is a dual opamp. This means you only need ONE to make a stereo headphone amp. The original cmoy used two OPA134 opamps which are only single opamps, in which case you would need two.
If you use two single opamps like the OPA134, yes you can use the same supply on both of them.
The DRV134PA is a balanced line driver. I'm sure you were thinking of the OPA134PA when you ordered it.
no actually i didnt order the drv134 for the headphone amp. i actually wanted to see about setting up my LM3886 amp to have balanced outs. but thats a different subject i'll probably be posting. im aware the difference between the opa134 and opa2132. But thanks for your post. My main worry was just splitting the input signal to go to both cmoys.
OK, maybe I was the one confused.
So you want to send a left/right signal to two separate stereo headphone amps?
If this is the case, there isn't anything special you need to do as long as your source can handle the lower input impedance. The standard cmoy circuit has an input impedance of 100k, so two amps with parallel inputs will make it a single 50k load for your source. I don't think your source will have a problem with 50k.
- Headphone Systems
- 2 channel headphone amp
