i have two 5"s running in exactly doulbe the volume for a single - shared.
the problem with two separate enclosures is that you may not get them exactly the same. the problem with a shared volume is that if the placement is not the same (symetrical etc), you may get different responses. but no, i can't back this up, i've never heard a setup with a problem as such.
