2 18 bass design
Was just wondering how this design would work for 2 18" selenium 18SW2P
Yeah it' very similar but I'm a lil bit confused with hornresp since I'm new at it so I was wondering if to just try building one and see how it goes but more work also..
Each driver has the recomm. volume and port size for a bass reflex ,I am not sure if it will work positioned like this to minimize distortion.
Ex-Moderator R.I.P.
Joined 2005
ah, a strange kind of "ripole"
mind you
its pro sound "subwoofer"
doesnt go so low, but instead louder
not really a domestic hifi thing
more in the party disco techno direction
look up ripole, which is a folded dipole
another "variations" is H-frame
plenty info on those
http://www.parts-express.com/pdf/264-385.pdf
Driver Properties
Type: Standard one-way driver
Company: Selenium Loudspeakers
Comment: Professional series
No. of Drivers = 2
Mounting = Standard
Wiring = Parallel
Fs = 36 Hz
Qms = 16.12
Vas = 6.32 cu.ft
Cms = 0.0884 mm/N
Mms = 221.1 g
Rms = 3.103 kg/s
Xmax = 6.5 mm
Xmech = 9.75 mm
P-Dia = 389.9 mm
Sd = 1194 sq.cm
P-Vd = 0.776 liters
Qes = 0.43
Re = 5.6 ohms
Le = 2 mH
Z = 8 ohms
BL = 25.52 Tm
Pe = 600 watts
Qts = 0.419
no = 1.872 %
1-W SPL = 94.87 dB
2.83-V SPL = 96.42 dB
Box Properties
Name:
Type: Vented Box w/ Active HP Filter
Shape: Prism, square (optimum)
Vb = 8 cu.ft
Fb = 40 Hz
QL = 5.944
F3 = 41.93 Hz
Fill = minimal
No. of Vents = 2
Vent shape = rectangle
Vent ends = one flush
Hv = 10.67 in
Wv = 3 in
Lv = 8.487 in
Active 12 dB/oct. HP Filter
Fx = 40 Hz
Qx = 1
Note the vent size, and the 40hz filter.
Code:
ID=28.00
Ang=2.0 x Pi
Eg=2.83
Rg=0.01
Fta=13.66
S1=0.01
S2=1560.08
Par=35.56
F12=0.00
S2=1560.08
S3=2590.32
Par=23.50
F23=0.00
S3=0.00
S4=0.00
L34=0.00
F34=0.00
S4=0.00
S5=0.00
L45=0.00
F45=0.00
Sd=1194.00
Bl=25.56
Cms=8.81E-05
Rms=3.11
Mmd=198.15
Le=4.26
Re=5.60
OD=2S
Vrc=231.00
Lrc=20.00
Ap=696.77
Lpt=17.78
Vtc=0.00
Atc=0.00
Pmax=100
Xmax=5.0
Comment=18SW2P Ctrl+O=23.5
  • 18SW2P.zip
That zip file is damaged.
Anyway, it's only a horn above 100hz, probably has a nice peak between 150hz~200hz.
"Thanks,but I need translation,haha"
You didn't give a port dimension in your first post. I figured it out for you, 10-5/8" tall, 3" wide, by 8-1/2" deep.
Use a 40hz high-pass filter, with a Q=1 if adjustable.
