15" + Mid + Horn
The bass drivers I will use will be C15-400B. PDF
Searching for a horn, I came across with CP 800TI from Beyma which has low 2nd and 3rd order harmonics for a compression driver. PDF
But it has the SPL value to high (for 1W). A L-pad will help but with some disadvantages.
The horn used in Beymas test is TD590. PDF
The polar response is not so great.
Next step.
As you can see from the graphs at 5W the C15 will have over 100dB at 50Hz.
It will be a problem matching this with a good mid driver.
The possibility of 15" + 2" driver will work only if I find one suitable for the job.
The test enclosure is 110 L, FB 45Hz, 20% Damping (40kg/m3). Full space simulation (anechoic).
Administrator
Joined 2004
Re-running.
I know that graphs are inaccurate and that`s why I will build a test box to assess it.
Later:
Same result. The box was rectangular due to laziness.
P.S.
Attached graphs from LEAP database.
First one is free air, second inf baffle.
