12v 4 Channel Amp, Ideally for a car.
Hello all,
I am in the market for an amplifier for a car based set-up.
Im attempting to build an all in one Android based car pc with 3G and etc.
The issue I have currently is a gap where the amp should be due to not being able to find something suitable. Which is where I turn to you guys.
To break it down:
The power comes straight from the battery, but is switched by the ignition supply though the ISO connectors. The system only powers up when the ignition is on. From that, I have 4 power connections, 2 x 12v outputs, for the preamps and amplifier, routed off before a 5v 5A regulator for the motherboard and a 5V case fan.
The motherboard itself has 2 stereo jack outputs which I have used to low noise stereo preamps to give them a little kick before they are properly amplified.
This is where the problem is. I need a 12v powered (ideally), 4 channel amp which has a reasonable wattage per channel which will give the at least same volume output that a stock head unit might give, if not better. The speakers themselves have a 90w (5 inch) and 180w (6inch) threshold, but Im sure thats not an issue. All 4 speakers are 4Ω.
Can anyone advise me further on the situation and any advice on what I should get? I'd like the amp to be as small as possible, 100x60mm or less.
Thanks in Advance
JuzzTF
JussTF - I just built and tested (literally an hour ago) a 4 channel amp using TA8251AH. I use a 96.52 x 63.5mm (3.8 x 2.5 inch) PCB by default, but there would be no problem shrinking this.
Sorry for the crappy photo ... I mounted this to an aluminum box for testing.
I cannot comment on how this compares to the original head unit.
