All our tubes oscillated under 3k3. Three indications. 1. Tube will not stabilize bias point completely, it drifts. 2. Weird noises. 3. More microphonic than normal. It will not settle to be a super built noval, but it will go significantly more silent regarding microphony from when oscillating. Under 20mA is more silent in general combined with 3k3 or over grid stoppers.
Peter Roodzant said:Hauke: You mention the 26 tube in your last post. Have you ever compared the 26 with the 12B4? Some people claim that the 26 is the Holy Grail and that all indirect heated tubes are not in the same league. What is your opinion?
Peter
Hi Peter,
yes, indeed, the 26 tube is a very nice sounding tube. But i cannot manage to make them quite; battery heaters, etc...
KR
Hauke
The hum problem associated with #26 was coming from the filement supply, when I'm not mistaken. See: http://www.vt52.com/diy/myprojects/amps/26bat/26bat.htmbarossi said:... i cannot manage to make them quite; battery heaters, etc...
vgeorge said:Well, Salas got me the bug to build one!
As I start collecting bits, I would like advise as to which transformer to buy for this pre. As I understand, I need one with 300V, 5v and 6v secondaries for the heaters. Which one is the best choice soundwise?
It is going to be tube rectified and shunt regulated with a mosfet CCS.
Any advise is welcome.
P.S I already ordered some tubes to get motivated!
310V-0-310V 0.3A, 5V 3A, 12.6V 1A (120VA custom Toroid, best is custom R Core)
GZ34 47u 450V 1K 5W 220u 450V to HV Shunt
12.6V to bridge to 10.000u to 317 on sink 12.2V set with trimmer under reg to 12B4A heaters in series.
vgeorge said:Thanks Salas,
as I was in Athens yesterday,I ordered one with 2x300V 200mA EI core, not so expensive.
After I finish the project and like it, maybe get an R-core one.
Do you know how makes R-core in Greece? Or I have to order from aboard?
Thanks,
George
From abroad. But forget for now. Use a separate PSU box as you normally do. Good luck with construction.
nicoch46 said:HI Salas have a Link for R-core supply?
Custom Magnetics in USA, and some pop up on ebay, like ECU Tamura.
Double C core are good too. Good value is Serbian Trafomatic. They do custom stuff, so I would ask for custom secondary values mains double C since they do valve output double C.
I will built in a saparate box.
I also need to find the 2n6520 for your HV shunt. No one seems to cary them!
Use MPSA94. If you go to a good shop and ask for PNP -400V TO92 they usually come up with something. I have found some NEC that way. Just give em a number like MPSA94 and they look up the equivalents guide and look for what they may have in their inventory.
i revised my preamp to that one:
For Pin 2+7 i used 3K9 grid-stoppers.
@cathode 1K2 and 470uF
@anode CCs from Kevin @ K&K Audio:
http://www.kandkaudio.com/accessories.html
I tuned the CCs to 15mA, this means ~160V at anode and ~18V across cathode resistor measured to earth.
I tried 4 differend 12b4a from different brands; all of them were pretty microphonic. Just tip the tube and you hear a "ping".
This is not what it should be!?
KR
Hauke
KR
Hauke
- Tubes / Valves
- 12B4 Preamp
