12ax7a replacement
Hi, I have loooooot of tubes, but I couldnt find 2x 12ax7a for my bass preamp (http://www.diyaudio.com/forums/showthread.php?threadid=83696)
What tube can I use for replacement?
there are some examples of what I have but dont know if I can use them.
6x ECL82
4x 6AQ5
2x 12au7
2x EF86
3x 6B6A
2x 6CG7
2x 6BZ6
2X 6CB6
2x 12BA6
5x 12AV6
thanks!!!
6x ECL82
4x 6AQ5
2x 12au7
2x EF86
3x 6B6A
2x 6CG7
2x 6BZ6
2X 6CB6
2x 12BA6
5x 12AV6
thanks!!!
12ax7a, 12DF7, 12DT7, 7025*, 7025a*, 12AD7 (filament issues possible), 12AU7 (in a pinch, may not work), 12AU7a (same warning), 12bZ7 (filament), 12DM7(filament).
*=exact replacement-cross
Then the Euro equivalent numbers for a true 12AX7 cross. ECC83*, CV492*, E83CC*, etc.
There is also a Russian one out there, can't quite remember right now.
Depending on how the heaters are powered in the circuit, other crosses are 'potentially' possible.
Be it known, though, that 12ax7's are common as grass and as cheap as it gets. Best to buy the proper tube.
KBK said:12ax7a, 12DF7, 12DT7, 7025*, 7025a*, 12AD7 (filament issues possible), 12AU7 (in a pinch, may not work), 12AU7a (same warning), 12bZ7 (filament), 12DM7(filament).
thanks you a lot!!!!!11
I found a place that still sells 12ax7a at u$s11, I will buy them today!!
thanks again!
KBK said:There is also a Russian one out there, can't quite remember right now.
Hello KBK,
you're refering to 6N2P - 6SS41. But beware heater is different than 12AX7.
http://www.giaime.altervista.org/china_eng.html
The 12AV6 double diode triode is regarded by some to be 1/2 12AX7 plus a couple of diodes, and as such, could be used in the circuit you are making. Provided, you allow for the12v heaters, the extra heater current needed, B7G not B9A sockets required, and double the amount of sockets needed.( single not double triodes).
All in all more work..... But if you're desperate.
Dont forget to tie the diodes to ground.
thyratron
thyratron
- Tubes / Valves
- 12AX7A replacement
