If all you want is short (relatively anyway) playtimes a battery (or multiple battery) setup is fine. You still need a charger, and the voltage will be constantly dropping. If you have the $$ and the inclination, a big transformer and monstrous caps will play as long as you please. Either will work.
Post photos when you finish though!
