110W Flyback
Hi, this is related to the prior post I did today... in certain way I answered myself one of the questions and decided to go thru with the 110W flyback, but I think I'll need a little help qith the main input filtering and surge supression.
Here I attach the only off-line SMPS I commertialized for a while as it is, just as a power supply, for a casino machine that needed 19Vdc - 3.42A, so this is a 70W off-line flyback converter, that works pretty nice, but didn't need to meet any standards that I know of, but it was in a metalic cabinet, so there was no problem...
Now I need something more adequate for a machine that maybe is going overseas, so, maybe hasn't to meet all IEEE standards, but at least I want it to throw the least possible noise at low cost to the mains power.
So, I'd be really grateful if you take a look to the schematic I post and tell what would you change, mostly in the input filtering, which is almost non existent
Thanx!!
You could insert 0.1uF 400v caps before and after the line filter, and across the CRAIL 100u reservoir cap. Insert an RCD snubber and/or transient/surge suppressor (transzorb/transil + UF diode[take a look at P6KE200]). You should use an auxilary power supply (an extra winding in the transformer) to fully power the UC3844.
Thanks.
Hi there and thank you all!
Well, I know this does not meet any standards, as I told you before, but works nicely just under 72W, the question is: is this circuit suitable for 130W?
I avoided the use of RCD snubbers and auxiliary windings, instead I used a passive "non-dissipative" snubber that uses the filtered spikes from switching-off to feed the PWM IC, reducing the leakage inductance in the transformer and using the energy that would be dissipated across the RCD snubber's resistor as a power source for the logic, hoping this would not affect the logic with noise...
Regards!
