100W Ultimate Fidelity Amplifier
..I built two of these PCB ax 14, both have the same problem, BIAS did not come to a standstill at zero !! I verified the operation P1 is ok, BD139 is on heat sink with insulation, the welds seem ok .... the PCB is very simple ... the margins of error are low .... I have not yet found the problem:confused::ashamed:
... I made measurements on this pcb, ... near the R16 I measure 0Volt .... All this because the BD139 is not placed on the heatsink of the transistors? strange
OK, quick check in to make sure I am on track.
AX14, first channel hooked up and measured. All .33ohm resistors measuring 10-11mv as is the output. All settled down once the heatsink warmed up, sitting on a steady 36C, its a fairly substantial heatsink (as per pic).
So does this all seem to be within spec?
Thanks.
Edit, after 15-20 mins the heatsink has cooled to 33c.
Joined 2013
Thanks.
Seems right on. .011/.33=33mA. Looks good, keep the pics coming!
congratulations on successful build.
Enjoy your music and post some pics if you decide to put it in a case.
I see that you have populated C13 and the diodes D6/D7. Instead of C13 , you could populate R23, a 10 ohm 0.25W resistor.
Thanks Prasi.
R23 is soldered under the board bypassing C13 so both options there.
The heatsink its mounted on is part of the case which I got from Aliexpress. Will post some pics once its all together.
And thanks for the board design etc. and help during my build. The boards are great to work with, very clearly labeled and all components fit well. Nice straightforward build.
