Wow!
Quite a few responses here for such a short period. I appreciate having so many more brains than my own.
For those of you who noticed, I posted another thread that noted my lack of knowledge when it comes to how component composition relates to specific applications.
I've built 2 phonostages. I used 5% carbon film resistors in one of them, and 1% metal in the other. The PS with metal film resistors had a much lower noise floor which I'd guess is what made the sound image more resolute and forward than that of its carbon filmed brother.
But as we all know, phonostages are not tuners. I'll definitely replace the resistors in the HK's phono section. I wonder if the linestage could benefit from the same treatment.
To me at this point, the HK receiver sounds OK but is clearly nothing special. If I destroy it (which is unlikely), I won't be too upset. I DO have the schematics. http://manuals.harman.com/hk/Service%20Manual/HK330b%20sm.pdf
Thanks again for the input and useful links. The ePanorama page is exceptional! Per-Anders, what exactly IS your avatar an image of?
My avatar is a Lithops Optica Rubra, a living stone from South Africa. Now the Lithops has grown and divided itself and looks much nicer
If you can't handle catcus due to too little water those Lithops may be something because they are more or less impossible to kill if you don't watering them too much that is.
http://www.mesembs.com/lithops/optica.htm
http://www.mesembs.com/lithops/index.htm
Seeds can be found here:
www.mesagarden.com (in USA)
http://www.mesagarden.com/mj2005.html
.... and now I have taken a picture also, see the avatar.peranders said:My avatar is a Lithops Optica Rubra, a living stone from South Africa. Now the Lithops has grown and divided itself and looks much nicer
LowRedMoon said:I've built 2 phonostages. I used 5% carbon film resistors in one of them, and 1% metal in the other. The PS with metal film resistors had a much lower noise floor which I'd guess is what made the sound image more resolute and forward than that of its carbon filmed brother.
There are only a very small number of resistors in the receiver that would benefit from replacement by lower noise ones, as you have already found the most likely place is the phono stages. However, only a small number of those resistors will make any difference as well - it's usually pretty obvious which ones will have appreciable effect.
- Design & Build
- Parts
- 1% metal film resistors - overkill?
