Sica 5" and 6" hifi coaxials measurements
Hello fi-guy! Okay thx for stating your subjective impressions so far!
So we have 4" , 5" and 6" coax drivers from Italy/Sica for a fair price , sad to see such rare feedback about them on the net!
DIY needs more spreaded around , gaining attraction for newbies!
If anyone has a most wanted link list for offer for DIY please add this one :
https://diy.midwestaudio.club/
Maybe there are much more links , if so throw us your best places!
plywood paradise where are you :)
Regarding 4, 5 and 6 inch sizes , these are hot babes , who cares about Klippel - looks are everything :
https://audiotechnology.dk/c-quenze/
https://audiotechnology.dk/flexunits/
Like a swiss watch but for your ear :)
Very over priced (probably because of low quantities) with very standard open tooling frames and other parts.
But your comment about looks isn't that far of.
Yesterday I spend an entire day talking with a client because the current idea didn't look right.
Which I also totally agreed with.
It's kinda fascinating, because at least 50-70% of my job is to fix these kinds of things.
Which than creates a tango dance again with the acoustic part.
Reactions: 1 user
Its a bit of both, but having dealt with the Sica 5.5 in small nearfield designs, it was evident by removing the HF element how little room there was for the tweeter itself.
It totally depends where de demodulation rings are being positioned.
There is a upcoming solution from another brand (which I mentioned before) and they still have a demodulation ring inside their coax.
Reactions: 1 user
I honestly don't see (or hear) the so called value in AT drivers. They have average sensitivity and FR for the type of cone material and profile they use.
I'd pit any of the Peerless NE series against these AT drivers. The NE123W, 149W and 180W are some of the finest paper cone drivers I've ever heard and worked with, especially being a Chinese built product. Large Ti VC formers, open cast frames with excellent ventilation and copper in the gap are relatively high end features, yet they usually sell for under $100. Too bad Peerless now made them available only in large quantities. The NE123 and to some degree the NE149 can even be considered as full range drivers.
Yes it seems the AT stuff from Denmark is somewhat outdated and very high priced .
The 4" is a 5" , having 96cm2 effective radiation area , and underhung coil! (but aluminium former to get a braking effect for excursions more than 3.5mm theoretical Xmax5/one-way) For this one 240eu seems okay for me , and the 5" is a 6" with 137cm2 area , only 265eu , not bad! Handmade drivers with good chance getting repaired with original parts!
A fair comparison of similar sized drivers would be awesome but rarely found , but recently I came across this one :
Even with the limitations of YTVids the R6meta delivers more clarity , depending on music content (quality) , checkout audio samples starting around 13:18min ... of course could be a false impression because the freq resp of the R6meta could have a broad peak of 2-3dB somewhere ...
I agree the NE149-4Ohm has a fantastic FR , measured by Hifi Compass - for a fair price (but remember it was way higher in the past) ...
At some point , all good drivers are sounding equal!(?)
The music is the ultimate decider :
Here some measurements.
Hopefully I can do a full set next week or the week after.
Not sure exactly about SPL, but must have been around 90dB @ 1m or so.
Measured with Line Audio Microphone at 96kHz Sample rate in a VERY stuffed little cabinet of just a few liters.
So some very small issues might show up from internal resonances.
edit: resonances will be around roughly 765Hz, 1150Hz and 3kHz
Nothing really to see there :)
Although we've already decided to go for the other mysterious coax
This is the SICA 5 inch coax.
blue: 2nd order
green: 3rd order
red: 5th order
(other harmonics didn't show any relevant data)
Woofer at 10cm:
Tweeter at 28 cm:
Freq resp of the tweeter on-axis, 26x40cm baffle driver placed at 30cm.
Distance about 80cm or so
There is a bit of a dip around 11.5kHz
I haven't checked other measurements yet or if that could be an issue of the baffle.
Nevertheless, any dip that high is not problematic.
Reactions: 3 users
Here some preliminary data of the mystery coax.
Levels aren't calibrated, so don't look at those.
No pixel peeping allowed either! ;)
I am nog gonna show the performance of the woofer.
Freq resp is 0, 15 and 30 degrees and is pretty workable.
It starts to have some issues above 12kHz or so, which seems to be common for these kinds of coax units
The 5 inch Sica has this as well, and is in fact even a bit worse.
Haven't checked the full directivity yet, but will do that in the next couple of weeks.
Distortion measured at 10cm and 51cm with a Line Audio microphone.
Didn't check the levels (ref to 1 meter) either.
I have to measure the impedance as well, but the report from the manufactuur says it has a Fs around 1500Hz.
Looking at the distortion graphs as well, I was hoping that the distortion would go up at a lower frequency.
2500Hz might be just doable.
The tweeter is smaller compared to the Sica btw.
Levels are NOT the same as previous measurements!!!!
The performance of the woofer will be heaps better than the Sica.
Reactions: 1 users
