My MOSFET amplifier designed for music
What I do if I have the real estate is have a cleared copper under the resistor and use a little solder paste to aid in heat dissipation onto the copper below it. Also you can increase solder pad size to act as heat spreaders. But then what is the point of making small smd pc boards.:oops:
Reactions: 1 users
Running power dissipation calculations using Mooly's sim for 70W 1KHz, the dissipation for the resistors I've currently got as 1206 film resistors are all well below their rated 0.25W figures. If I went SMD for the power resistors it would be a different story. If it were a problem, I would probably go with mini-MELFs.
Reactions: 1 user
Layout with increased heat spreaders for Q3/Q5 and gate resistors now located close to MOSFET gate pads. Heat spreaders and output tracks now have solder mask adjusted to aid heat dissipation. Also included some text.
  • Mooly_Dual_SMD2_1.pdf
Reactions: 1 user
