Hamptone
music soothes the savage beast
Joined 2004
Any experiences with this little circuit?
Reactions: 1 user
Joined 2004
It's allive! Well, i found 2N4392, so thats what i used.
Could not located mpsa18, so i used 2xBC550 as darlington.
Used C2705 for lower bjt as current source, since i have plenty from yamaha pre repair.
I found small pcb from other pre project, so i improvised.
It sounds juicy, musical, with nice second harmonic sweetness to it.
Joined 2004
Ok, please do, if it looks ok, i will definitely try it.
I made a typo in previous post, i was looking for mpsa14, darlington, not mpsa18...those i found plenty, as well as mpsa06, 42, 92 and others. None darlington. Hence i made my darlington from two bc550. But i am certain i have mpsa14 somewhere.
If irf610 works, i have plenty too.
Joined 2004
Since its raining, i made some progress. Made second set with 2N4392. Both perform well. Due to variations in jfets, there is some disbalance between channels, so i recomment matching.
Both sound great. Thd is ~ 0.06% to 0.08%. Most importantly, pure second harmonic, very little 3rd and up.
Here are some measurements from rightmark.
Reactions: 1 users
Joined 2004
Building more clones, will be testing various input jfets. First i will try 2N5457, originally used jfet in the hamptone. Than this is what else i found in my stash. I am aware that some jfets might need some bias adjustments, i am not going to individually deal with it for now.
2SK246
PF5102 (i think this is replacement for mpf102)
J112
J113
LSK170
2SK30A
Then i found some, which are not jfets, but small depletion mos, not sure if they would work here, but it may be worth the try.
DN2535 vfet
BSS129 dmos
Reactions: 1 user
