Ok, I see it if I download the PDF just not in the image in the post. The dimensions are very close to what I ended up at for the foam core homage.
http://www.diyaudio.com/forums/atta...ore-mini-build-fh3-inspired-foamcore-plan.jpg
http://www.diyaudio.com/forums/full...pired-foam-core-mini-build-3.html#post3339779
And it looks like this:
Beautiful design, I modeled up with a little larger horn back and slender curve.
Tony
Tony
Hi Tony,Beautiful design, I modeled up with a little larger horn back and slender curve.
Tony
That’s superb modeling you did there to get compound curves like that - was that done using a “swept curve” approach?
A curved plywood implementation would look fantastic.
Thanks for looking into this. I really like the organic shape - like a sail on a boat filled with wind.
Thanks X, here is pictures of the 3d print of the model.Hi Tony,
I was going to wait to play music until I got the pair done but been having a little trouble with my printer for my last piece. The bottom part took 10 day to print. The top half took 6 days. I may plug the on in this weekend. Inhale the two pieces clamped together and have acoustic stuffing in place.here is a picture of two pieces looking at the joint.
no, printing 20% infillAre you printing these as Solids !?
- Full Range
- XRK Homage tp the Frugel-Horn but for 3" drivers
