Bora is a nice guy from Serbia - Yugoslávia
there will be,but in next 10 days. boards are in Germany where i work,but I am now in my beautiful Serbia for vacation, until orthodox christmas...
and so,exactly ten days (and few thousand hours) later... :)
Reactions: 1 users
72 emiter resistors in 4 pcb's. i should have bought 5W instead 3x2W as i did,but i have had troubles to find them - non-inductive. now they don't look nice,but they will work as they should.
I’ve never heard a rational explanation as to why they should be non-inductive. I don’t think you need to be constrained by that idea.
Reactions: 1 user
I'm laying out now , the only issue there could be with a inductive resistor is if it is close to a sensitive circuit or if it can be affected by
some other inductive element , such as a output coil. I've never seen any Wolverines with inductive's , but it would be interesting if this was tested.
I would expect very few PPM's to be introduced.
Mostly a myth , if the layout is right. Like .... don't put a inductive next to a input stage section.
OS
some people claim that they can hear the sound difference between carbon and metal-film resistors in a circuit. i certainly can not but anyway i use metal-film resistors. same reason is why I used non-inductive emiter resistors. i have built it for myself,i have had a time and will to do it - so i did it.
although i wouldn't be sorry if I used 5W inductive resistors too.
ii am not in any way trying to persuade anyone to do anything in any particular way from any particular reason.
this is my hobby, not an obsession 😀
