SSLV1.1 builds & fairy tales
diyAudio Chief Moderator
Joined 2002
Heaters is a special case, I know L-Adapter is being used for heaters, don't know about 1.1 shunt, not usually. What I would do is skip Zobel and use 100uF output and no remote sensing for heaters. Useless in a steady load as heater. Maybe it gets noise interference when Zobel for heaters.
Joined 2002
Found it in the notes:
4. Output Zobel/Ecap
There is C104(204,304) Cout position. There an MKT & R107(207,307) form a Zobel.
That way, given the minimal ESR of a plastic capacitor, the R element stays defined as
designed in. An electrolytic can be used also as per BOM, in that case the R107,207,307
position MUST be shorted with a jumper. It is speedier using the Zobel, plastics are more
linear also, still an Ecap is sometimes needed since it has bigger value and gives more
damping if a load is much reactive or has unpredicted parallel parts on its rails,
like very small decoupling elements, should you will notice instabilities cooperating with
the reg. If there are no problems even with heavy current loads, the MKT + R is best.
Joined 2009
Not good.
Joined 2009
Reactions: 1 user
