I have a few of the later blue versions of these regulator boards available if anyone is interested? They're unassembled (wrt to the through hole components) and unused.
PM me id interested.
All sold now.
Hi Ales,PM Sent!
bregards,
Aleš
how can I get your TPS7A4700 regulators? I need some 4 pcs.
Marek
Ales stopped selling these and has been quiet for quite a while.
I've had good results with these regulated supplies, which might suit your requirements?
https://www.ldovr.com/category-s/114.htm
As is typical for these types of supplies the specs are copied from LDO datasheets. Not based on measurements of actual devices.I've had good results with these regulated supplies, which might suit your requirements?
I'm not sure of the point you're making, there was no suggestion to the contrary and I simply reported having good results.As is typical for these types of supplies the specs are copied from LDO datasheets. Not based on measurements of actual devices.
if you want i can send you a board for free and you can post your measurents.My point was only that it would be better to show real measurementt
Sorry, but I think designing, implementing and selling these kind of devices without measurements is a flawed approach. How would you improve your products based on my measurements?if you want i can send you a board for free and you can post your measurents.
Why do you believe I need to improve it (particularly the TPS7A4700 board I've been selling since 2016)?How would you improve your products based on my measurements?
You claim that the specs of my boards are incorrect (copied from LDO datasheets) but can not prove it, and I think it is a "flawed approach". I have measurements from my client (measured at the UWA metrology group, for example). I have received repeated orders from many laboratories and universities (like the National Institute of Standards and Technology, Jet Propulsion Laboratory, the Large Binocular Telescope Observatory) and i believe it is a much more valuable evaluation.
- Vendor's Bazaar
- TPS7A4700 low noise LDO regulator PCB
