wonderful, how would I order a complete setup?SMPS440-TK4 can be configured to supply 63V as long as its a single rail output.
And no need to use 2 X SMPS440-TK4 to get 63V.
Hey Sami, what's the difference between the COBRA-S2R2 and the COBRA-S2?COBRA-S2R2 1400W output power with unmatched performance.
Rock-solid output voltage with any input voltage range 120VAC ~ 265VAC
Both units are identical, with a capability of 1500W.Hey Sami, what's the difference between the COBRA-S2R2 and the COBRA-S2?
But, COBRA-S2 has two DC outputs to drive two amplifiers, and two AUX connectors especially for Purifi amplifiers in stereo build.
Each amplifier has its own power cable to ease the wiring.
Any potential concerns for cross-talk using the same V+/V- rails for both channels?Each amplifier has its own power cable to ease wiring.
No problems ever reported when feeding two channels from the same rails.Any potential concerns for cross-talk using the same V+/V- rails for both channels?
The best option for the Wolverine amplifier is the COBRA-S2 for stereo setup.For wolverine amplifier, what would be the most optimal smps? For example, I am considering as an alternative a linear power supply with 500 VA transformer into 59V (55 V for smps).
The Sparkos regulators made improvements in many Purifi amplifier builds.Noted. Looks like your smps will make my assembly much easier. Just need to save some cash first. Is sparkos upgrade has a significant difference on sq?
I am not sure if I have stock, let me know what voltage you are targeting
- Vendor's Bazaar
- Audio SMPS units for sale
