6N16 12x preamp srpp/cathode follower with printed circuit board design.
I used the one in the attachment.
Last weekend a view friends came over to my place to do a listening test.
I had lower the amplification factor of the tube buffer to 1x with a resistor at the input and used a switch to bypass the tubebuffer with a noemal signal wire.
Nobody could tell the difference between the tubebuffer or the signal wire.
This was a confirmation for me what i had notised before. This tubebuffer ad no coloration to the signal.
Nice little project, seen that schematic somewhere before...errors and all.
From my experience messing with this type of tube (6S6B = half 6N16B) I found that in reality the optimum THD result is obtained with anode voltages quite different to what you claim (Koifarm).
In fact, with B+ over 250V (as long as anode volts in quiescent state are within datasheet limiting values), and also with Ia in the region of 4-6mA.
I.e. even with anode as low as 50V, but B+ supply up to 300V. It all depends on the anode load.
Your right, with 10k load and 1V output the B+ of 140v is good for low distorsion. When you need 10v output and/or low load you need to change the resistors and/or B+.
It means that you cant hear tube coloration sound?!
