It is just a 6db per octave slope.
I try to specify transistors so that PSRR will be high up to the maximum current, I don't rate it just based on power dissipation limits.
BTW: Somehow I doubt this, but is it possible to run multipliers in parallel to increase current?
Also, the ancient Jean Hiraga from 'Audiophile (a magazine in France) said that the Darlingnot couple used will easily be prone to very high frequency odscillations.
If anyone using this gets a small sound that is sorta like electrical farting it seems that too much capacitance after it will cause that. Not sure how voltage used will determine the capacitance that is too much. At 50v 1800uf was too much along with the circuits 200-400uf~.
Hello keantoken,
I built up your k-mult according to attached circuit.
input AC is 15~16 VAC,, rectified to 22 VDC. follwed by lm317 , which is adjusted to 17 VDC output.
The k-mult further drops it down to 14.8VDC.
The led flashes and switches off at power-on. ( i could only see a faint single point glow of led, if i really see closely).
As soon as i connect a 1k load resistor ( about 16mA), the led switches on.
otherwise every component is ok ( resistors).
I have used bc327 / 337 and MJE15032/33 pair.
regards
Prasi
regards
Prasi
thanks keen,
tried with a 500 ohm load, still same thing. grounding arrangement can be seen in the below image.
clean ground (317/337 and CMX share a common ground point near the leds.
rectifier and bulk caps are far upstream.
I will try replacing the 337/327 and see..
my load demand is quite low, ESP HPA. In that case will mje15033/32 pair be ok?
regards
prasi
regards
prasi
That layout looks okay. I notice I didn't recommend the 15033/32 for the Kmultipliers. That is likely because I didn't have any to test, or if I did, they were not stable.
I would suggest finding a way to load the kmultipliers over 25mA, or switching to D44/45H11G. You can also try switching to BC5xxC for the TO92s, that has also worked before.
Just to make sure it is not another problem, please give me the voltage at each transistor pin.
Thanks kean, I will put them to good use in next project with recommended transistors ( an AKSA class A HPA) . meanwhile for this esp hpa , i built up a simple crc+lm317/337 as per Power Supply for Preamps , works fine for the purpose.
regards
prasi
Prasi i was about to something very similar for my hp amp. I believe the original configuration was found in old parasound psu by john curl? My question is tho, since 317/337's max current output is 1.5a, does that influence the k multiplier's performance on where its current limit is set?
Keantoken, im debating on whether to use this or the typical darlington cmx for my class a headphone amp. Reading up on pros and cons of cfp vs darlington it seems to me that cfp is harder to stabilize vs darlington having more 2h, at least in the output stage. But also i remember seeing that the transistor characteristic of an active psu will show up on the load. Then since darlington has more 2h, can we assume that as a cmx the same characterstic will be heard on the final sound?
Check Arrow looks like 4,000 in stock.Since the D45H11 seems to be unavailable at present (like so many other parts): What other transistor do you recommend as a substitute?
- Power Supplies
- Keantoken's CFP cap multiplier
