Vacuum Tube SPICE Models
Disabled Account
Joined 2013
12DT5 Tung Sol model:
Code:
* Created on 08/25/2021 03:00 using paint_kip.jar
* [url=http://www.dmitrynizh.com/tubeparams_image.htm]Model Paint Tools: Trace Tube Parameters over Plate Curves, Interactively[/url]
* Plate Curves image file: 12dt5.png
* Data source link: <plate curves URL>
.SUBCKT 12DT5 P G2 G K ; LTSpice tetrode.asy pinout
* .SUBCKT 12DT5 P G K G2 ; Koren Pentode Pspice pinout
+ PARAMS: MU=11.88 KG1=1313.26 KP=41.34 KVB=12 VCT=0.2 EX=1.471 KG2=3682.33 KNEE=12.58 KVC=1.81
+ KLAM=3.125E-10 KLAMG=4.433E-7 KNEE2=16.44 KNEX=0.08206  KNK=-0.2 KNG=0.01861 KNPL=6.546 KNSL=0.06755 KNPR=124.44 KNSR=53.97
+ CCG=12.5P CGP=0.57P CCP=4.9P VGOFF=-0.6 IGA=0.001 IGB=0.3 IGC=8 IGEX=2
* Vp_MAX=500 Ip_MAX=250 Vg_step=4 Vg_start=0 Vg_count=11
* X_MIN=107 Y_MIN=15 X_SIZE=620 Y_SIZE=613 FSZ_X=1296 FSZ_Y=736 XYGrid=false
* Rp=1400 Vg_ac=20 P_max=9 Vg_qui=-20 Vp_qui=300
* showLoadLine=n showIp=y isDHP=n isPP=n isAsymPP=n isUL=n showDissipLimit=y
* showIg1=y isInputSnapped=y addLocalNFB=n
* XYProjections=n harmonicPlot=y dissipPlot=n
* UL=0.43 EG2=250 gridLevel2=y addKink=y isTanhKnee=y advSigmoid=n
RE1  7 0  1G    ; DUMMY SO NODE 7 HAS 2 CONNECTIONS
E1   7 0  VALUE=  ; E1 BREAKS UP LONG EQUATION FOR G1.
+{V(G2,K)/KP*LOG(1+EXP((1/MU+(VCT+V(G,K))/SQRT(KVB+V(G2,K)*V(G2,K)))*KP))}
RE2  6 0  1G    ; DUMMY SO NODE 6 HAS 2 CONNECTIONS
E2  6 0  VALUE={(PWR(V(7),EX)+PWRS(V(7),EX))} ; Kg1 times KIT current
RE21 21 0 1
E21  21 0 VALUE={V(6)/KG1*ATAN((V(P,K)+KNEX)/KNEE)*TANH(V(P,K)/KNEE2)} ; Ip with knee but no slope and no kink
RE22 22 0 1 ; E22: kink curr deviation for plate
E22  22 0 VALUE={V(21)*LIMIT(KNK-V(G,K)*KNG,0,0.3)*(-ATAN((V(P,K)-KNPL)/KNSL)+ATAN((V(P,K)-KNPR)/KNSR))}
G1   P  K  VALUE={V(21)*(1+KLAMG*V(P,K))+KLAM*V(P,K) + V(22)}
* Alexander Gurskii screen current, see audioXpress 2/2011, with slope and kink added
RE43 43 K 1G ; Dummy
E43  43 G2 VALUE={0} ; Dummy
G2   43 K  VALUE={V(6)/KG2*(KVC-ATAN((V(P,K)+KNEX)/KNEE)*TANH(V(P,K)/KNEE2))/(1+KLAMG*V(P,K))-V(22)}
RCP  P K  1G     ; FOR CONVERGENCE
C1   K G  {CCG}  ; CATHODE-GRID 1
C2   G P  {CGP}  ; GRID 1-PLATE
C3   K P  {CCP}  ; CATHODE-PLATE
RE23 G 0 1G
GG G K VALUE={(IGA+IGB/(IGC+V(P,K)))*(MU/KG1)*
+(PWR(V(G,K)-VGOFF,IGEX)+PWRS(V(G,K)-VGOFF,IGEX))}
.ENDS
I am trying to model the Tubelab SP for operation with a PL84/EL86. I had to remodel the power supply so that the driver/splitter B+ is closer to the original design, so hence the two B+ supplies in the schematic (275v + 216v).
I have done something stupid and I just cannot get the model to work, at least I do not see any output at the loudspeaker.
If someone could take a quick look and point me in the right direction, I'd appreciate that!
  • SPP_1a.asc
  • 12AT7.sub.txt
  • 6CW5.sub.txt
Disabled Account
Joined 2013
vt4c tube datasheet - Google Search
211-VT4C model:
Code:
* Plate Curves image file: 211-GE-VT4C.png
* Data source link:
.SUBCKT 211_GE 1 2 3 ; Plate Grid Cathode
+ PARAMS: CCG=6P  CGP=14P CCP=5.5P
+ MU=12 KG1=3928.74 KP=451.14 KVB=249.72 VCT=-2.52 EX=1.458
+ VGOFF=-2.62 IGA=8.906E-6 IGB=0.04944 IGC=2.4 IGEX=2
* Vp_MAX=2200 Ip_MAX=160 Vg_step=20 Vg_start=40 Vg_count=15
* Rp=4000 Vg_ac=55 P_max=75 Vg_qui=-48 Vp_qui=300
* X_MIN=90 Y_MIN=40 X_SIZE=765 Y_SIZE=563 FSZ_X=1296 FSZ_Y=736 XYGrid=false
* showLoadLine=n showIp=y isDHT=n isPP=n isAsymPP=n showDissipLimit=y
* showIg1=y gridLevel2=y isInputSnapped=n
* XYProjections=n harmonicPlot=n dissipPlot=n
E1 7 0 VALUE={V(1,3)/KP*LOG(1+EXP(KP*(1/MU+(VCT+V(2,3))/SQRT(KVB+V(1,3)*V(1,3)))))}
RE1 7 0 1G  ; TO AVOID FLOATING NODES
G1 1 3 VALUE={(PWR(V(7),EX)+PWRS(V(7),EX))/KG1}
RCP 1 3 1G   ; TO AVOID FLOATING NODES
C1 2 3 {CCG} ; CATHODE-GRID
C2 2 1 {CGP} ; GRID=PLATE
C3 1 3 {CCP} ; CATHODE-PLATE
RE2 2 0 1G
EGC 8 0 VALUE={V(2,3)-VGOFF} ; POSITIVE GRID THRESHOLD
GG 2 3 VALUE={(IGA+IGB/(IGC+V(1,3)))*(MU/KG1)*(PWR(V(8),IGEX)+PWRS(V(8),IGEX))}
.ENDS
Disabled Account
Joined 2013
http://www.china-hifi-audio.com/images/PSVANE-tube/PSVANE-211-TII-vacuum-tube-007.jpg
Psvane 211-HiFi Series
Characteristics are quite close to 211 RCA curve.
Code:
PSVANE 211-TII model:
**** 211_TII ** Advanced Grid Current **********************************
* Created on 08/31/2021 04:28 using paint_kit.jar 3.1
* Plate Curves image file: 211-TII.png
* Data source link:
.SUBCKT 211_TII 1 2 3 ; Plate Grid Cathode
+ PARAMS: CCG=6P  CGP=14.5P CCP=5.5P
+ MU=11.64 KG1=2208.15 KP=589.39 KVB=889.01 VCT=-3.98 EX=1.346
+ VGOFF=-4 IGA=8.906E-6 IGB=0.04944 IGC=2.4 IGEX=2
* Vp_MAX=1800 Ip_MAX=400 Vg_step=20 Vg_start=20 Vg_count=15
* X_MIN=56 Y_MIN=16 X_SIZE=787 Y_SIZE=475 FSZ_X=1296 FSZ_Y=736 XYGrid=false
RE2 2 0 1G
.ENDS
Disabled Account
Joined 2013
211 RCA model:
Code:
* Created on 08/31/2021 04:50 using paint_kit.jar 3.1
* [URL="http://www.dmitrynizh.com/tubeparams_image.htm"]Model Paint Tools: Trace Tube Parameters over Plate Curves, Interactively[/URL]
* Plate Curves image file: 211-RCA.png
* Data source link:
.SUBCKT 211_RCA 1 2 3 ; Plate Grid Cathode
+ PARAMS: CCG=5.4P  CGP=14P CCP=4.8P
+ MU=11.64 KG1=1397.72 KP=3536.33 KVB=4994.4 VCT=-7.995 EX=1.27
+ VGOFF=-12 IGA=8.906E-6 IGB=0.04944 IGC=2.4 IGEX=2
* Vp_MAX=2000 Ip_MAX=1600 Vg_step=25 Vg_start=200 Vg_count=15
* X_MIN=38 Y_MIN=8 X_SIZE=802 Y_SIZE=647 FSZ_X=1296 FSZ_Y=736 XYGrid=false
RE2 2 0 1G
.ENDS
Disabled Account
Joined 2013
31 RCA model, try it:
Code:
* Created on 08/31/2021 20:43 using paint_kit.jar 3.1
* Plate Curves image file: 31.png
* Data source link:
.SUBCKT 31 1 2 3 ; Plate Grid Cathode
+ PARAMS: CCG=3.5P  CGP=5.7P CCP=2.7P
+ MU=3.8 KG1=9180 KP=51.2 KVB=210 VCT=-0.2175 EX=1.414
+ VGOFF=-0.6 IGA=0.001 IGB=0.3 IGC=8 IGEX=1.6
* Vp_MAX=250 Ip_MAX=30 Vg_step=5 Vg_start=0 Vg_count=20
* Rp=4000 Vg_ac=55 P_max=3 Vg_qui=-48 Vp_qui=300
* X_MIN=49 Y_MIN=35 X_SIZE=763 Y_SIZE=571 FSZ_X=1296 FSZ_Y=736 XYGrid=false
RE2 2 0 1G
.ENDS
Disabled Account
Joined 2013
Paint Tool can generate DHT model for A1 or A2. 31 has 2V and 130mA filament so Rfil=2/0.13=15.4 is used. Please try if any better:
Code:
* Created on 09/01/2021 11:05 using paint_kit.jar 3.1
* Data source link:
.SUBCKT DHT_31_A2 1 2 3 4 ; P G K1 K2
+ PARAMS: CCG=3.5P  CGP=5.7P CCP=2.7P RFIL=15.4
* Vp_MAX=250 Ip_MAX=30 Vg_step=5 Vg_start=20 Vg_count=20
* showLoadLine=n showIp=y isDHT=y isPP=n isAsymPP=n showDissipLimit=y
RFIL_LEFT    3  31 {RFIL/4}
RFIL_RIGHT   4  41 {RFIL/4}
RFIL_MIDDLE1 31 34 {RFIL/4}
RFIL_MIDDLE2 34 41 {RFIL/4}
E11 32 0  VALUE={V(1,31)/KP*LOG(1+EXP(KP*(1/MU+V(2,31)/SQRT(KVB+V(1,31)*V(1,31)))))}
E12 42 0  VALUE={V(1,41)/KP*LOG(1+EXP(KP*(1/MU+V(2,41)/SQRT(KVB+V(1,41)*V(1,41)))))}
RE11 34 0 1G
G11 1 31 VALUE={(PWR(V(32),EX)+PWRS(V(32),EX))/(2*KG1)}
G12 1 41 VALUE={(PWR(V(42),EX)+PWRS(V(42),EX))/(2*KG1)}
RCP1 1 34 1G
C1 2 34 {CCG} ; CATHODE-GRID
C3 1 34 {CCP} ; CATHODE-PLATE
RE2 2 0 1G
EGC1 81 0 VALUE={V(2,31)-VGOFF} ; POSITIVE GRID THRESHOLD
GG1 2 31 VALUE={0.5*(IGA+IGB/(IGC+V(1,31)))*(MU/KG1)*(PWR(V(81),IGEX)+PWRS(V(81),IGEX))}
EGC2 82 0 VALUE={V(2,41)-VGOFF} ; POSITIVE GRID THRESHOLD
GG2 2 41 VALUE={0.5*(IGA+IGB/(IGC+V(1,41)))*(MU/KG1)*(PWR(V(82),IGEX)+PWRS(V(82),IGEX))}
.ENDS
Disabled Account
Joined 2013
6E5P-I (6Э5П-И) Russian military pulse tetrode tubes model:
**** 6E5P ******************************************
Code:
* Created on 09/05/2021 19:20 using paint_kip.jar
* Plate Curves image file: 6e5p.png
.SUBCKT 6E5P P G2 G K ; LTSpice tetrode.asy pinout
* .SUBCKT 6E5P P G K G2 ; Koren Pentode Pspice pinout
+ PARAMS: MU=34.61 KG1=417.43 KP=2365.08 KVB=43.39 VCT=0.001396 EX=1.777 KG2=1270.08 KNEE=13.09 KVC=2.792
+ KLAM=2E-6 KLAMG=8.015E-4  KD=173704.09 KC=110716.95 KR1=1.33 KR2=0.24 KVBG=0.2139 KB1=7.179 KB2=0 KB3=0 KB4=0.1965 KVBGI=-0.46 KNK=0.00178 KNG=0.03673 KNPL=0.6205 KNSL=0.002871 KNPR=47.52 KNSR=25.06
+ CCG=15P CGP=0.065P CCP=2.55P VGOFF=-0.6 IGA=0.001 IGB=0.3 IGC=7.6 IGEX=1.6
* Vp_MAX=240 Ip_MAX=130 Vg_step=0.5 Vg_start=0 Vg_count=9
* X_MIN=38 Y_MIN=25 X_SIZE=829 Y_SIZE=570 FSZ_X=1296 FSZ_Y=736 XYGrid=false
* Rp=1400 Vg_ac=20 P_max=8.3 Vg_qui=-2 Vp_qui=300
* UL=0.43 EG2=150 gridLevel2=y addKink=y isTanhKnee=n advSigmoid=y
E4   8 0  VALUE={V(P,K)/KNEE/(KVBGI+V(6)*KVBG)}
E5  81 0  VALUE={PWR(V(8),KB1)}
E6  82 0  VALUE={PWR(V(8),KB2)}
E7  83 0  VALUE={PWR(V(8),KB3)}
E8   9 0  VALUE={PWR(1-EXP(-V(81)*(KC+KR1*V(82))/(KD+KR2*V(83))),KB4)*1.5708}
RE4  8 0  1
RE5 81 0  1
RE6 82 0  1
RE7 83 0  1
RE8  9 0  1
RE21 21 0 1
E21  21 0 VALUE={V(6)/KG1*V(9)} ; Ip with knee but no slope and no kink
G2   G2 K  VALUE={V(6)/KG2*(KVC-V(9))/(1+KLAMG*V(P,K)) - V(22)}
RE23 G 0 1G
.ENDS
Reactions: 1 user
Disabled Account
Joined 2013
6B7 RCA pentode section model:
Screen current is derived from transconductance curve of 2mA max.
Code:
**** 6B7 ******************************************
* Created on 09/06/2021 18:36 using paint_kip.jar
* Plate Curves image file: 6b7.png
.SUBCKT 6B7 P G2 G K ; LTSpice tetrode.asy pinout
* .SUBCKT 6B7 P G K G2 ; Koren Pentode Pspice pinout
+ PARAMS: MU=10 KG1=8962.8 KP=46.82 KVB=15.24 VCT=0 EX=1.4 KG2=53760 KNEE=14.79 KVC=1.799
+ KLAM=1.588E-8 KLAMG=3.186E-4  KD=0.44 KC=0.14 KR1=0.0013 KR2=0.064 KVBG=0.015 KNK=-0.044 KNG=0.006 KNPL=50 KNSL=11 KNPR=120 KNSR=29
+ CCG=3.5P CGP=0.007P CCP=9.5P VGOFF=-0.6 IGA=0.001 IGB=0.3 IGC=8 IGEX=1.54
* Vp_MAX=400 Ip_MAX=10 Vg_step=3 Vg_start=0 Vg_count=20
* X_MIN=30 Y_MIN=14 X_SIZE=800 Y_SIZE=502 FSZ_X=1296 FSZ_Y=736 XYGrid=false
* Rp=1400 Vg_ac=20 P_max=2.25 Vg_qui=-28.5 Vp_qui=300
* UL=0.43 EG2=100 gridLevel2=y addKink=y isTanhKnee=n advSigmoid=y
E4   8 0  VALUE={PWR(V(1,3)/KNEE/(V(6)*KVBG),2)}
E5   9 0  VALUE={SQRT(1-EXP(-V(8)*(KC+KR1*V(8))/(KD+KR2*V(8))))*1.5708}
RE4  8 0  1
RE5  9 0  1
RE21 21 0 1
RE23 G 0 1G
.ENDS
Disabled Account
Joined 2013
EL84 Mullard model:
Code:
**** EL84_ML ******************************************
* Created on 09/06/2021 22:58 using paint_kip.jar
* Plate Curves image file: el84-ML.png
.SUBCKT EL84_ML P G2 G K ; LTSpice tetrode.asy pinout
* .SUBCKT EL84_ML P G K G2 ; Koren Pentode Pspice pinout
+ PARAMS: MU=20.34 KG1=548.3 KP=141.5 KVB=153.6 VCT=0.2 EX=1.316 KG2=1731.12 KNEE=36.88 KVC=1.814
+ KLAM=5.06E-9 KLAMG=3.815E-7 KNEE2=1.438 KNEX=3.534  KNK=-0.01791 KNG=0.01267 KNPL=0.00988 KNSL=0.6384 KNPR=14.52 KNSR=113.68
+ CCG=10.8P CGP=0.5P CCP=6.5P VGOFF=-0.6 IGA=0.001 IGB=0.3 IGC=8 IGEX=1.32
* Vp_MAX=400 Ip_MAX=175 Vg_step=2 Vg_start=0 Vg_count=10
* X_MIN=74 Y_MIN=29 X_SIZE=620 Y_SIZE=544 FSZ_X=1296 FSZ_Y=736 XYGrid=false
* Rp=1400 Vg_ac=20 P_max=12 Vg_qui=-9 Vp_qui=300
* UL=0.43 EG2=300 gridLevel2=y addKink=y isTanhKnee=y advSigmoid=n
RE21 21 0 1
RE23 G 0 1G
.ENDS
