Boyuu hifi Equis A10 EL34B+6N2 SE Tube Amplifier with 5Z4P rectifier: review and mod
At which supply voltage and bias?
KT77 A.F. BEAM PENTODE
Base: OCTAL
Uf=6,3 V
If=cca 1,4 A
Typical characteristic: Ua=250 V
Ug2=250 V
-Ug1=15 V
Ia=100 mA
Ig2=10 mAS=10,5 mA/V
Ra=23 K
μ=11
ygg-it,
What is the DCR of your 16 Ohm speaker?
That might explain the better sound when it is connected to the 8 Ohm tap.
The damping will be greater on the 8 Ohm tap than the 16 Ohm tap.
The load at certain bass frequencies will 'appear' to be lighter on the 8 Ohm tap.
The load at certain mid frequencies will 'appear' to be lighter on the 8 Ohm tap.
It all depends on the particular loudspeaker design.
6L6
Moderator
Joined 2010
Hello! This is an english language forum, can you please post in engilsh? Using google translate is sufficient. Thank you.
Salut! Ceci est un forum en anglais, pouvez-vous s'il vous plaît poster en engilsh? L'utilisation de Google Translate est suffisante. Merci.
:D
I am sorry for going back to the early Posts, Modification # 10 . . .
If it sounds better, it is probably related to the low quality of the output transformer.
Consider the capacitance of the plate end of the primary, to the secondary.
If you ground one end of the secondary, you have more capacitance from the plate to ground through that primary to secondary path.
But as you already know, safety has been compromised.
Safety First!
Ground the output transformer's secondary common wire.
Prevent the "Surviving Spouse Syndrome"
A question for A10 owners: Does anyone have the spec. for the 'uprated' OPTs and Power Tx?
I'm sure that the quoted output of 12wpc is optimistic, so are the OPTs 5w or more?
I have got my hands on a bare A10 chassis and want to have a go at building an improved version, ideally with the same OPTs or slightly higher rating, but same footprint as the chassis is pre-drilled.
The uprated OPTs are potted, someone must know where I can get them from!
Douk wanted an arm and a leg, more than the cost of a whole new A10 infact...
