Translation:
22580, это форум на английском языкеWhy are you using the BD139 / 140? They are low-frequency, and the IR2110 is more than enough. You are doing it in vain.
Зачем вы используете BD139/140? Они низкочастотные, а так же IR2110 более чем достаточно. Вы делаете это зря.
i use 2sa1020 and 2sc2655 , when using ir chip direct without a buffer , the ir2110 gets hot
thanks manoj . noted
below the measurement of this topology but in russian vvvvvv
Hi stewin,
Thanks for your reply.
your fsw?when using ir chip direct without a buffer , the ir2110 gets hot
Hi stewin,
your fsw?
The fsw is about 275khz
D200
Hi
Tested this board. 223khz freq irf540n mosfet 30-0-30v supply. High side mosfet gets real hot.
Has anybody made this one?
Any help and feedback will highly be appreciated.
hi all , i am finishing my layout based on tl071 will post development and more pictures as i continue , .
comments and ideas are highly welcomed and appreciated
hi all just completed the layout , now its just developing the board
the files are below have fun all
- Class D
- Class D Amp with LM566, LM393 and 2XIRF530
