Behringer DCX2496 digital X-over
DCX modding and now some measurements
Hi
Found a PC, in the bedroom, with digital out and line ins, first pic is the Selectronic DCX the second my own modded DCX....
Sorry made pics, not the best but it shows the THD.
Cheers, Tojoko.
Administrator
Joined 2004
Yes, better. But that mostly looks like 50Hz mains noise.
You can do single tones in the RTA window and Spectrum mode. I found different harmonic structures at 44, 440, 1000, 5000 Hz. Pick the frequencies you like. It's often easier to see what's happening in spectrum analyzer mode.
Hello there, what are the cheapest/fastest mods to do on the DCX knowing the fact that it is connected via XLR in inputs A/B/C from my EMOTIVA CMX2 and feeding 3 bi-amp speakers (low/high filters).
the thing is that I have some ground noise that I would like to get rid of.
Thank you in advance!
Administrator
Joined 2004
Tojoko, thanks for the measurements, I am able to open them no problem.
But I don't understand what is going on here. The noise floor in the second measurement show spikes that do not look mains frequency related. Overall distortion is low, but it looks very spiky. Maybe it's a clock problem?
What are you using to get the digital signal to the DCX and what are you using to get the analog signal back into REW?
Administrator
Joined 2004
Yes, that's what I meant. The DCX is meant for pro line level which is a good bit higher than consumer line level. That means that if you are using the analog inputs your signal levels will be low compared to the noise levels. That might be what is causing your ground noise, or at least making it more obvious. Are you going in and out balanced?
Gain structure is important, and can be difficult with the DCX.
Administrator
Joined 2004
The DCX is basically unity gain from in to out. But it's made for a hot signal such as would be coming from a mixing console. If the input VU meters aren't hitting near red on your loudest peaks, then you'll run into noise problems.
You might also have a ground loop, although I've found the stock input to be robustly immune to hum and buzz in balanced mode. If you are coming from an unbalanced source there are several different ways you can wire the input. First check to hear if the buzz goes away if you disconnect one or booth inputs.
passive out DCX2496
Hi Pano
Did a stepped measurement and recalibrated soundcard, how doe this look to you, now...
cheers, Tojoko.
  • Tommod5.zip
