What is the max safe PSU voltage for FH9 if is BD139/140 used? On that sch is +/-50V? Thanks,
hi
in post number 12329 i put my fh11 with 3 pair irf640n/9640n
pcb is very compact and nice....12*6 cm
sound be good.instead of 150 ohm mr mile tell me put 330 ohm.
but when i power on for 2 seconds i have a few hum with +50/0/-50.after 2 seconds every thing be ok.whats problem?
if they are rated to 80V,rail voltage should not exceed 40V at worse. those transistors at their place in schematic would see almost rail to rail voltage at maximum power.
hi
Do you have gerber files you could post? Did you only allow spacing for TO-220 devices, or is there room for TO-247 (IRFP240/9240) devices?
Use KSC3503/1381 for best results
warm regards
Andrew
Yes, that’s what I used and it worked well. If you plan on taking it above 40v, switch the drivers to be on the safe side. They cost no more really. I suppose you could chance it and if they blow out, you just replace them but you might get some magic smoke.
100W Ultimate Fidelity Amplifier
no pcb designed with to220 pac.but i can change this for to247
OK, i made simulation and receive those results for FH9:
PSU +/-45V
So, BD139/140 are safe? Actualy, they are on the half of the max Vce voltage in this situation.
But when one is active at the moment, the other sees the full power supply voltage (45+45)...
KSC2690AYS and KSA1220AYS are also very good (Vce=160V)
More simulation pics can be found here:
SC409 — ImgBB
SC414 — ImgBB
SC413 — ImgBB
SC412 — ImgBB
SC411 — ImgBB
https://ibb.co/z5Bn35K
PSU +/-45V
SC409 — ImgBB
SC414 — ImgBB
SC413 — ImgBB
SC412 — ImgBB
SC411 — ImgBB
PSU +/-45V
SC409 — ImgBB
SC414 — ImgBB
SC413 — ImgBB
SC412 — ImgBB
SC411 — ImgBB
what program do you use to simulate
Microcap 12 which is now free.
So, regarding FH9 and to be on the safe side, please do not use BD139/BD140 with PSU higher than ~ +/-35V. For bias BD139 is OK.
AX11 does not polarize
Good morning, I can't adjust my AX11 bias. In the tests the lamp remains on and biases with 350mV and each emitter. I've already changed all the transistors, i installed a 5k pot (in place of 4k7), checked for short circuits, but it didn't work, rotate the pot but do not change bias.
I made some measurements:
Differential pair: BC546
BxC=1,95V, 2,03V
CxE=1,31V, 1,37V
BxE=595mV, 594mV
BC546
BxC=2,70V
CxE=630mV
BxC=2,07V
BC639 and BC640
BxC= 2,03V, 1,95V
CxE= 1,37V, 1,31V
BxE= 594mV, 595mV
BD139 and BD140
BxC= 1,98V, 2,07V
CxE= 2,65V, 2,71V
BxE= 630mV, 639mV
BC517
BxC=2,72V
CxE=3,38V
BxE=661mV
2SC5200 and 2SA1943
BxC=2,65V, 2,68V
CxE=3,30V, 3,35V
BxE=672mV, 694mV
I forgot to measure mpsa92, if necessary I will do the measurement.
To help is welcome, thank you.
(I'm testing the amplifier on the right)
BxC=1,95V, 2,03V
CxE=1,31V, 1,37V
BxE=595mV, 594mV
BC546
BxC=2,70V
CxE=630mV
BxC=2,07V
BC639 and BC640
BxC= 2,03V, 1,95V
CxE= 1,37V, 1,31V
BxE= 594mV, 595mV
BD139 and BD140
BxC= 1,98V, 2,07V
CxE= 2,65V, 2,71V
BxE= 630mV, 639mV
BC517
BxC=2,72V
CxE=3,38V
BxE=661mV
2SC5200 and 2SA1943
BxC=2,65V, 2,68V
CxE=3,30V, 3,35V
BxE=672mV, 694mV
*...bias voltage is 13v to 15v across the emitter resistors." that is almost impossible!
And also the output transistors are getting hot
- 100W Ultimate Fidelity Amplifier
