6N23P preamp
PCB hanging in rubber,DC filament heating,HS delay,mute,all components mounted on subframe.
BH 6550
This is my first tube amp ever and I love it. Need to finish some minor details... Many thanks to Bandol83, gingertube, prasi...for their work and devotion
That looks fantastic. Can I ask how you managed the machining of the top plate?
6N23P preamp
COOOOL
5 tubes for each channel or....?A view of my phono amp.
Four tubes per channel, the other 2 tubes are in the power supply I use a 12AX7 and a 12AU7 instead of two 12DW7...
6N23P preamp
Very ingenious circuit and aspect
Beautiful!This is my project on two tubes ECL80... mini amplifier for headphones and speakers, power out 2 x 1.5W.
Did you make the enclosure yourself or ......
BTW : What is the headphone impedance?
Nice and compact build. I love this kind of constructions.
When things cool down a bit I will try to finish some projects of about this size and I am looking to power them with a smaller DC/DC-converter module - two on the way. Planning to use a 12V MC battery.
- Tubes / Valves
- Photo Gallery
